Digital I/O
Pattern I/O
David:  Thanks for taking the time to whip up a sample, unfortunatly I do not have access to LabVIEW as I am writing my application in C++ with the NIDAQmx driver.
As to my timing diagram, I have included it below.  There are two different types of commands that I can do, a "read" and a "write."  When doing a "write" I don't need to acquire any samples from the DUT.  When doing a "read,"  I generate 2 samples, followed by acquiring two samples.  The top bar represents 8 bits of input data, DUT -> 6536.  The second bar represents 8 bits of output data, 6536 -> DUT.  The RD, DS and EN bit are all generated by the 6536.
By overflow/underflow conditions, are you refering to write and read buffer issues?  If so, I dont think I have to worry about them.  I just want to issue one of these commands and hold until I want to issue the next command.  (Which at its most basic is keeping EN high I guess.)
Thanks for the help.
-Rob
Message 11 of 12
(1,363 Views)
May I see ur code plz ?
Masood
Message 12 of 12
(1,019 Views)
