Digital I/O
Pinout for USB-8452 connector
Does anyone have the pinout for the USB-8452 connector? The NI USB-8452 product web page has a link to the NI-845x Hardware and Software manual but this only documents the USB-8451 OEM pinout. I found the USB-8451 OEM pinout does not match the labels on the USB-8452 flying lead set (15280A-0R25). Example pin 7 in the USB-8451 OEM pinout is SCL but on the SB-8452 flying lead set this is ground.
(4,118 Views)
Accepted by topic author Sparky...
See page 3-14 of NI-845x Hardware and Driver Software Manual
https://tmesystems.net/
(4,115 Views)
I came across the same problem. Did you find the pinouts for NI 8452 ? Could it be figured out by any other means?
(2,298 Views)
If for whatever reason you couldn't or didn't want to refer to the user manual at the link shared by ZYOng, here are some snapshots,
Santhosh
Soliton Technologies
(2,285 Views)
