Digital I/O
Please update NIDAQmx for SUSE
NIDAQmx has been released in 2005, I think it is due for a minor upgrade to say the least. It is working great in my environment, but after several hacks and a few hours. I hope NI implements this suggestions:
* Update the NI-DAQmx 8.0 page here:
http://joule.ni.com/nidu/cds/view/p/id/376/lang/en
to point that the user needs to install NIKAL. Furthermre, remove the OBSELETE 1.2 NIKAL from NI-DAQmx RPM, and let the user _first_ install the latest NIKAL, whatever that may be, then install NI-DAQmx.
* Fix installer problems. There are a couple of problems with NI-DAQmx (under bin/)
1. Change "asm_offsets.h" to "asm-offsets.h" (Line 89)
2. UTS_RELEASE is no longer set in SUSE, so the check in line 117 is invalid "# check that the headers dir that we found is for the correct version of  the kernel". I removed that check completely and it installed fine.
Please make these changes and release NI-DAQmx for SUSE.
(3,251 Views)
Hi KNRO,
Thanks for your feedback!  We always welcome user feedback on how we can make our products better.  To make product suggestions in the future, I recommend that you go to ni.com/feedback and follow the link for "give us feedback" to be sure that it will be seen by the appropriate group.
Luke
(3,237 Views)
