Digital I/O
Port/Pin connection chart for cDAQ 9171
I'm looking for a diagram and/or table that lists the ports and their respective pin numbers for the 9171 USB Chassis. Does such a document exist?
(4,443 Views)
The 9171 is just a chassis. What IO module do you have?
(Or do you wan to make your own module?)
(4,427 Views)
Below is the link for the user manual to the NI cDAQ-9171 as well as the spec sheet for the NI cDAQ-9171:
NI cDAQ-9171 User Manual:
(1.) https://www.ni.com/docs/en-US/bundle/cdaq-9171-9174-9178-features/resource/372838e.pdf
NI cDAQ-9171 Data Sheet:
(2.) http://www.ni.com/datasheet/pdf/en/ds-178
I hope this helps!
(4,406 Views)
The NI 9403 I believe.
(4,403 Views)
So you want the pinout for the module, not the chassis. That should be easy to find.
(4,399 Views)
Page 10 of this document appears to have the pinout diagram for the NI 9403:
NI 9403 Getting Started Guide:
https://www.ni.com/docs/en-US/bundle/ni-9403-getting-started/page/overview.html
Is this what you are looking for?
(4,382 Views)
