Digital I/O
Powering a 5V relay using Vernier SensorDAQ
I am trying to power a 5V relay using Vernier's SensorDAQ.  Would it be possible to send the signal using the board's digital I/O terminals?  If so, how would I do this?  I'm thinking that I need to use an analog terminal to get to 5V.
I'm sorry in advance, but circuitry and programming is not my expertise.
(Using LabVIEW 10)
(3,373 Views)
Hello Space Cowboy,
Depending on your relay current requirements, you may or may not be able to control your relay directly with a digital write. It looks like the SensorDAQ has a current limit of 8.5 mA for each digital line, which may not be enough for your relay. If you need more current, you can use a digital write to drive a transistor and complete your circuit with the +5V pin on the SensorDAQ. As far as the programming goes, you will just need to use a Digital Write to control when your signal goes high/low and it will output 5V. If you're using LabVIEW, there are plenty of shipping examples in the Help files and online at ni.com that cover writing to a digital line.
Jake H | Product Manager
(3,358 Views)
