Digital I/O
Precise response needed
   I made a vi to drive a vco circuit .I am varying the frequency from 70 to 148. For some values of frequeny  I am getting the exact respose ie the frequency  I am entering is getting at the output using Ni USB 6009 DAQ card, ie the 12 bit binary generated at DAQ output is sufficent. It have 12 bit digital output pin.I want to make the response more precise
I am adding some value
148.1  1111 1111 1111
129     1011 1101 1001
Please help me to solve is issue
 Thanks in advance
with regards
DK
(5,409 Views)
First of all, I am seeing two different equations in your code to change the frequency to a voltage.  One is a comment on the front panel and the other is what you have in the expression node.
Secondly, it is looking like the values you want are from different offset/gain pairs.  Maybe you want something more complex of a conversion than linear.
(5,389 Views)
