Digital I/O
Problem with DAQMX on a 6025E !!
I work on a DAQ 6025E and I can't use the example "Write Dig Port.vi" and all others example on digital output with DAQMX. There isn't any hardware failure because the same installation functions correctly with the traditional DAQ. I want to use these channel parameters: Dev1/port2.
I already tested to make a reset device and use "line or port configuring vi" but without successes.
Thanks for your help!
(3,301 Views)
Hello V.GRAF,
Thank you for contacting National Instruments.
The problem may be that you need to reset your board for DAQmx in Measurement and Automation Explorer (MAX).
Open up MAX. Expand the Devices and Interfaces tree under My System. Expand the NI-DAQmx Devices tree. Right click on our DAQ card and select Reset Device.
After you have done this, try running the example again. Cycle through the entire range of inputs using the Data to Write control. If it still does not work correctly, let me know.
Matthew C
(3,300 Views)
