Digital I/O
Problem with the TTL Output
Hi i am having a problem with my TTL Output. I am using a CVS-1450 and working on a application using LabVIEW 8.0.1, the problem is when i set and Output on 1 the display with a multimeter is just 1V i need the 5V for my application i dont know why it is only giving me 1V.
(3,378 Views)
Hi Andium,
What terminal block do you have? It is possible that it is not suplied correctly. You can check the datasheet for the power requirements at:
http://digital.ni.com/manuals.nsf/websearch/2F46DB52AEBA37BE86256F5C00822E90
Is that problem happening in just one port or in all of them? If the problem is with all of them, I believe that it's about the power supply. If its with just one, maybe your CVS has something wrong. You can check the following link about it.
http://digital.ni.com/public.nsf/allkb/94F7B3B464ED9A628625722E0061858B
What version of IMAQ 1394 driver are you using?
I hope this helps.
Thanks for using NI forums!
Arturo Vargas
National Instruments de México
(3,337 Views)
