Digital I/O
Programe Digital outputs of DAQMax different logical states
I have NI USB 6216 DAQ bord and want to controle relay board using logical states (ex:1,0,01). I am using Labview 7.1 and want to programe 4 Digital outputs to obtain 16 logical outputs such as 0001,0010,0100........1111. One time one combination and then change to next accordingly. Best regards Wije
(3,752 Views)
What exactly is the problem? All that you have to do is count from 0 to 15. Wire the iteration terminal of a for loop to the DAQmx Write. One of the most basic examples that comes with LabVIEW is called Write Dig Port. Couple of very minor changes and you're done.
(3,737 Views)
Thanks Denis
I got some idea, If I write Digital channal 1D boolean and one sample may be correct. I will try and let you know my problem solved or not
Wije
(3,727 Views)
Problem was solved
(3,707 Views)
