Digital I/O
Programming Nidaq in Visual C# .NET
I have a Problem using Nidaq-DLLs within my application
on a network drive.
Calling my application on a local directory, everything works fine,
but from  a network drive I get the following error:
************** Exception Text **************
System.IO.FileLoadException: Could not load file or assembly 'NationalInstruments.DAQmx, Version=8.7.20.11, Culture=neutral, PublicKeyToken=4544464cdeaab541' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)
File name: 'NationalInstruments.DAQmx, Version=8.7.20.11, Culture=neutral, PublicKeyToken=4544464cdeaab541' ---> System.Security.Policy.PolicyException: Required permissions cannot be acquired.
   at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission)
   at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission)
   at VML_Zielanzeige.VML_Zielanzeige.WriteDigitalLine(Int32 iLine, Int32 iData)
   at VML_Zielanzeige.VML_Zielanzeige.OnTimerVerriegeln(Object sender, EventArgs e)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
It seems that I don´t have the permisson to call a Function from the DLL.
What can I do?
Regards, Jürgen
Message 1 of 1
(4,170 Views)
