Digital I/O
Push-in spring terminal connector plugs for NI USB-6501
Dear forum,
the NI USB-6501 is shipped with screw terminal connector plugs. I want to replace them by push-in spring terminal connector plugs (connecting/disconnecting a wire is much easier). It seems that the NI USB-6501 has COMBICON Jacks (see User Guide, page 5), so there should be matching plugs available by Phoenix Contact.
Can somebody give me a part number or a link for matching push-in spring terminal connector plugs, please?
If not: Does somebody know the exact pin spacing of the NI USB-6501?
cpschnuffel
(1,502 Views)
Hello cpschnuffel,
I never heard about this type of terminal connector plugs. But I think you can find this kind of things from the eBay or AliExpress. As you mentioned you should be attended that your terminal connector plugs have COMBICON Jacks.
Best Regards.
(1,430 Views)
Quick way, if you have the USB-6501 on hand, just get a vernier caliper and measure the pin-pin spacing and filter potential lugs from Phoenix
Santhosh
Soliton Technologies
(1,422 Views)
