Digital I/O
Read/Write to SD Card using SDIO In sbRIO-9607
Hello.
I am using sbRIO-9607.
I am using the RMC connector and have created CLIP and set up the pins to use SDIO.(Vcc, CLK, WP, CD, CMD, DAT [0-3])
I am currently using PmodSD as a controller.
My question is, if I set up the SDIO pins of the sbRIO-9607 and connect it to each Pins of the Pmod, can I write or read the data on the SD card?
If not, I have to control the ports I assign, but I can't control them. How do I control it?
Message 1 of 1
(2,729 Views)
