Digital I/O
Reading Parallel bits and sending them over USB
I have an FPGA which is sending data off on the GPIO pins. I want to read these bits in parallel and then send them to my pc over a USB cable. I have been looking at a couple different options to do this including the USB 6501. Is this device a good option for this application or is there a better option out there.
Thanks in advance.
(2,304 Views)
Which FPGA card?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,295 Views)
Is there a clock line with the data?
If so you will need a card that can do hardware timed or correlated digital IO. From memory the 6501 can't do this. I think this is the comprehensive list: https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/sampleclockdio.html
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(2,260 Views)
Thank you for the responses.
I am using a DE2-115 Board with a Cyclone IV FPGA.
There is no clock line with the data.
I am wanting to send each bit off of its own pin on the GPIO port and have the NI DAQ take those bits and send them to my PC over a USB connection.
(2,230 Views)
