Digital I/O
Redistribution of NI Components for PCI-6503 (DIO 24)?
I'm using the PCI-6503 for simple reading and writing of digital points. I need to install the required NI software during the installation process of my software. What dll's, exe's, system files, etc. need to be installed, what compoments need to be registered, what entries must be made in the registry, and what other things must be done by our installation such that the PCI-6503 card will work properly in our customer's system?
(3,721 Views)
Clarification: All the software is running under NT4.0
(3,721 Views)
Hello;
You just need to install the NI-DAQ driver to customer's computer, and then hook the board up. The board should then be automatically recognized by the machine and any application making NI-DAQ function calls should be working properly.
Regards
Filipe A.
(3,721 Views)
"install NI-DAQ Driver" implies the end user of our software must run the NI installation package. Can the NI-DAQ driver installation package be run from our installation such that the user does not have to respond to a bunch of questions? i.e. does the NI-DAQ installation package have a 'silent' mode of operation?
(3,721 Views)
