Digital I/O
Reverse Polarity on DC Power Supply
Hello, I am currently attempting to reverse the polarity from a DC power supply. Basically, I want to create an option in labview which can switch the polarity of a voltage at a given step. I was wondering if there was a way to do this through a DAQ? or should I look at making a whole circuit like an H-Bridge? The application is to a semi-conductive material which behaves differently at different voltages, and when polarity is switched. just trying to automate my test.
(1,915 Views)
Please provide details about the Power supply model and probably a connection circuit. Typically DC Power Supply work only in the first quadrant.
If your power supply is capable of operating in two quadrants, check if it supports automation using Serial/USB/LXI/GPIB. If it does, then you could control this from LabVIEW using appropriate commands.
Santhosh
Soliton Technologies
(1,862 Views)
