Digital I/O
RoboRio Connectors
I'm trying to find the correct connectors for all the available ports on the RoboRio.   The students want to create a cable harness for their robot.  Thanks
Michael
(3,701 Views)
The best list of connectors that I could find for the roboRIO is linked below.
https://decibel.ni.com/content/docs/DOC-39578
You may also get input from other teams if you post to ni.com/frc or chiefdelphi.com as I would be surprised if other teams haven't wanted to do this before.
(3,665 Views)
Jacobson, thanks for the information but unfortunately it doesn’t provide the connectors I’m trying to find.    I was looking for the RS-232, I2C, DIO, RSL, Relay, Analog in, PWM, SPI as well.   I’ll check the other forms you mentioned as well.
(3,590 Views)
