Digital I/O
SCB-100: Where can i find a pin diagram?
I'm just trying to test a SCB-100 terminal block with a PCI-6515 card, and i have no idea where my grounds are. the manual for this device, as found on-line, doesn't explain the pin-out at all. can anyone help?
(3,981 Views)
The SCB-100 is just a generic straight-through connector block assembly and the pin out is whatever the DAQ device you have connected to it. Pin 1 of the ribbon cable connector is connected to screw terminal 1, pin 2 to screw terminal 2, etc. You need to look at the pin out of the 6515 to determine which pins are your signals and grounds.
(3,973 Views)
Here's a link to a spec sheet with the pinout for your board:
http://www.ni.com/pdf/products/us/ni_651xdatasheet_with_rt.pdf
-Alan A.
(3,965 Views)
