Digital I/O
SPI and I2C Driver API
Hello All,
    I am trying to use an NI 9402 module to utilize I2C communication to talk to a compass sensor as it is stated possible here: https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html.
     The fpga layer compiles succesfully, but I am recieving no indication that the communication is successful (there are lights that are supposed to blink), and the read returns nothing but 255.   I have attached a screenshot from the front panel showing the parameters I am using.  Taking an oscilloscope to the scl pin reveals a regular square wave as expected.  The SDA line also shows data being actively changed as well (the program is indeed outputting).
The datasheet for the sensor I am using including expected communication results is shown here.
http://www.elechouse.com/elechouse/images/product/GY-26-USART%20Digital%20Compass/gy-26%20manual.pdf
Any help that could be given to get this sensor up and running would be greatly appreciated!
Daniel
(7,093 Views)
Could you list your cDAQ chassis as well?
(7,050 Views)
I am using a crio 9022 with an fpga backplane.
Thanks!
Daniel
(7,032 Views)
the ni link you refered is either moved or deleted (msg by ni). can you share the snapshot of your vi both fpga and on rt side to get a clear picture.
(7,018 Views)
Hi!
I've tried to compile the example but it had an error. Could you share the bitfile for proving it?
Thanks!
(6,084 Views)
Or just had an extra period....Here's the proper link: https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html
(6,079 Views)
