Digital I/O
SPI communication using DIO 96
Hi:
     I am very newbie of labview. Now I have a project is to read the ADC value from IC LTC1867 with using DIO 96. This is my first time to do SPI communication i try to write code to read ADC but I always get low signal.
  Can any one please help me? (I attach the code I write.)
Message Edited by TK Chang on 09-05-2006 09:40 PM
(4,821 Views)
Hi Chang,
PCI-DIO-96 is a static DIO device and it is the recommended device for I2C Applications. You would need a correlated digital I/O for I2C Applications. In other words, you need board which can precisely correlate data bits with clock.
I would recommend using USB-8451. It has High-level, easy-to-use LabVIEW API. It can act as I2C master interface with clock rates up to 250 kHz which is well with in the range of LTC1867 rate. This would make your programming and interfacing very easy.
For further information, please refer to the following product page.
https://www.ni.com/en-us/support/model.usb-8451.html
Hope this helps.
Have a great day!
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(4,794 Views)
Hi Kalyan:
          Thank for advice. I will try it.
(4,781 Views)
I think it is possible to write SPI code using the DIO-96
(3,741 Views)
