Digital I/O
Should Change detection have limited triggers?
Hi All,
I am using change detection in an event model (as per Example) and I am only getting a finite number of events.
It varies between about 350 and 750 events.
This is problematic as it is being implimented in a continuously running system.
Any suggestions
PXI 6289
LV 10.0.1 Realtime on 8195.
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
(4,004 Views)
Accepted by topic author Timmar
Well Timmar,
have you checked your block diagram to make sure that it uses "continuous samples"
The example uses the default (finite samples) which is fine to show you the basic operation but becomes problematic if you want to do multiple events over a long period.
make that change and retry your code.
(4,001 Views)
Thanks Timmar, That worked perfectly.
(I have posted my solution so that future explorers can easily rectify the problem)
(4,000 Views)
