Digital I/O
SignalExpress and the USB-6259
We are trying to use SignalExpress and the USB-6259 to generate digital outputs without success. Do all the digital I/O lines on this module require an external sample clock to work correctly. Any information would be appreciated
(3,773 Views)
Hello Greenies
Thank you for your post. I have noted that you have also posted on another of our boards, to save repeating steps with you, would it be ok if we worked on the other board regarding your query?
Regards
Stephanie L
National Instruments UK and Ireland
(3,763 Views)
Ok by me
(3,761 Views)
