Digital I/O
Simulated DAQ input state
Hi everyone,
Is there a way where we can chose the state of simulated DAQ cards?
For an example I have simulated NI PCI 6229 and accessing the Port 1 line 0-7, but while running the code the values read from simulated DAQ keep on changing with no control over it.
Is there a way where I can change the value of each input as per my need, this would allow me to validate my application in a better way.
(3,229 Views)
Hi Vkas1,
The Simulated devices show a similar kind of behaviour.
The NI PCI 6229 that you are referring as reading continuously, the simulated devices return Digital data as if each 8-bit port were counting up.
The https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0PxCAI&l=en-US link over here explains all the details regarding Simulated devices.
Thanks!
(1,985 Views)
