Digital I/O
Simulating Digital Inputs (PCI-6527)
I am currently working on a project involving reading digital input of a NI PCI-6527 card.
The computer containing this card is not plugged to anything yet, because we are awaiting material from our suppliers to do so, so I would like to know if it’s possible to make the computer "believe" that the card is receiving different signals on its input ports. I would like to know if it is possible to do so using only NI MAX or do I have to use LabView ?
I followed this tutorial (http://www.ni.com/tutorial/3698/en/) but it doesn’t seem to allow doing what I want as I can only read inputs and write on outputs of a virtual device.
Dave
(3,097 Views)
How would you expect to have a light turn on without power?  The hardware for the inputs is expecting a physical voltage in order to operate the internal optocouplers.  Pages 3-8 through 3-12 of the manual show the physical connections of both the inputs and outputs.  You can create a voltage setup on the outputs then wrap them back into the inputs to see how the card actually responds.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,061 Views)
Unfortunately, the simulated DAQ just toggles the digital line with each read.  Agreed, not useful at all.
Go give this idea a kudos: Interactive DaqMx simulation interface
(3,059 Views)
