Digital I/O
Static write with a PFI using HSDIO products
I need to do a simple write on a PFI channel to in order to reset my DUT.  How do a static write directly to a PFI channel?
--Brian
(3,758 Views)
You can mimic a static write to a PFI line by using DAQmx routing.  Use the DAQmx Connect Terminal VI to route an internal logic high or low to one of the PFI lines.  Be sure to disconnect the route when you are done, otherwise you will not be able to export other signals to that PFI line, or use it as a trigger.  I've included a small LV 7.1 VI as an example.
-Jared
(3,749 Views)
