11-07-2014 10:24 PM
Can multiple USB-4431 units be synchronized together using the digital i/o port to share the sample clock? looked at docs but I don't fully understand the pin assignments for the digital i/o connector.
If it is possible would it require labview level timing or would NIDAQmx handle it via channel expansion?
Thanks.
11-10-2014
07:31 AM
- last edited on
11-21-2025
01:49 PM
by
Content Cleaner
I believe I have found the answer. Yes the clock can be shared via PFI0 and setting one master device with additional devices as slaves.
References:
http://digital.ni.com/public.nsf/allkb/8CD44F64AFAC6EAC862572CF0059A48F?OpenDocument
