Digital I/O
TCP/IP connection lost after connection
I am including a dll file for a digital I/O module. The DLL file works perfectly under VB.NET and C #.
But under LabView I have problems.
The TCP/IP connection does not stay upright, that means. it breaks as soon as a connection is established.
The DLL file also has an integrated KeepAlive function, but this is not influenced by the outside.
Who can help me to solve the problem?
thank you in advance
Natalie
(2,417 Views)
Hi Natalie1984,
What do you mean by it breaks as soon as a connection is established?
Does your code works at least once? - Do you send actual data through "SEND_STATUS_32" Method?
Do you get any error?
Can you try any other dll in LabVIEW, if it works correctly?
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,354 Views)
