Digital I/O
Testing methodology for PCI-DIO-96
I am intergrating a server with the PCI-DIO-96, and want to tests its functionality to make sure it works before shipping it out.
(3,227 Views)
Greetings,
The simplest method of testing the PCI-DIO-96 is to use its Test Panel in Measurement & Automation Explorer (MAX). If you navigate to the device in MAX, you will be able to right-click on it and launch its Test Panel. This will allow you to test the basic functionality of the device. If you need to test all of its functionality (handshaking, etc.), I would suggest that you run the appropriate example programs for the development environment you are using (LabVIEW, CVI, Visual Basic, etc.).
Good luck with your application.
Spencer S.
(3,227 Views)
