Digital I/O
The parallel acquisition problem of two acquisition cards(CRIO)
Hello everyone, I have a problem in data collection. I want to collect the data of NI9232 and NI9237 in PARALLEL in FPGA and read it in RT terminal. During the test, there was no problem for each acquisition card to collect separately, but when I combined the program into a FPGA, the sampling rate with one acquisition card at the RT end could not be changed (increasing or decreasing the value of the sampling rate button, the program sampling rate remained unchanged). I tried to run only one acquisition card FPGA program on THE RT side, and it can run normally. I have attached my collection program (the program is based on LABVIEW routine, the interface may be a little ugly, because I have tested it for many times and I am in a bad mood, please do not mind), I hope you can give me valuable advice, thank you!
Message 1 of 1
(853 Views)
