Digital I/O
Toggling ND_PATTERN_GENERATION_LOOP_ENABLE
When trying to turn off ND_PATTERN_GENERATION_LOOP_ENABLE, Set_DAQ_Device_Info returns an error message when passed the ND_NONE data as specified in the documentation, however has no objection to ND_OFF. Is the documentation wrong on this point?
(3,101 Views)
Hi rgaddi,
Yes, you are correct. You must use ND_OFF. There is a mistake in the documentation. Here is the usage...
iStatus = Set_DAQ_Device_Info (iDevice, ND_PATTERN_GENERATION_LOOP_ENABLE, ND_OFF);
I will file a bug to have it corrected. Thanks for the catch.
Ron
Applications Engineering
(3,101 Views)
