Digital I/O
Trigger configuration for a NI 6533
Roy,
If you run your code, but do not give a trigger, does it timeout? (it should) And are any samples written? (no new samples should be written) Does all of this behavior happen the same if you use a rising edge trigger?
I would like to ask that you post a screen shot of your scope, showing the trigger and output signal, so that I can see the incorrect signal being produced before the trigger happens.
David L.
Systems Engineering
Message 11 of 11
(896 Views)
