Digital I/O
Triggering DataLogger from Analog Input
I have a cDAQ 9189 with 8 Slots with NI 9201 as AI and NI 9401 as DI/DO. I want to Transfer analog Signals to a TTL Signal(Output) so as to trigger a data logger.
(2,814 Views)
HI himanshu25,
Could you describe it a bit more, what do you mean by:
"I want to Transfer analog Signals to a TTL Signal(Output)"
You want to convert analog signals to digital? Or send out some digital signal based on the analog input?
AmbrusG
Ambrus
Technical Support Engineer
??It's just business ??
(2,779 Views)
I want to convert Analog Signals to Digital Signals. I did it in the attached vi but I am not sure of the frequency is same or different.
(2,775 Views)
Well I don't see any attached VIs in any of your comments. Could you pleas add it again?
AmbrusG
Ambrus
(2,773 Views)
