Digital I/O
Triggering an event in event structure by a digital line
Hi  I Wrote code for my test application and all was going to well. I am using an event structure to handle menus and to start a test sequence. Until now I was just using a button on the front panel until the code was finalised and now thatIm happy with it all I want to start the test sequence by a digital line going high. But here I realised my problem.  I tried setting property nodes and local variables for the button On the front panel but this doesn’t work.  I know that the event structure is really only for front panelEvents but it’s worth a try...  Can anyone help??
(3,552 Views)
How are you monitoring the digital line? Are you using DAQmx? If so, you might want to consider DAQmx events.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,543 Views)
Hi Barry,
I think you will need to use a dynamic event terminal on the event structure, then register the event similar to the following:
Tony Gibbs
NIUK Applications Engineer
(3,533 Views)
