Digital I/O
Tristate a 6509 channel programatically
I am trying to programatically tristate a PXI-6509 output channel using the DaqSystem.TristateOutputTerminal Method described in NI-DAQmx .NET Framework 2.0 Help  and attached below.
Can you tell me what the Output terminal string should be?  I tried "/dev1/Port11/Line0" but that did not work.
Sets a terminal to high-impedance state.
Public Sub TristateOutputTerminal( _
   ByVal outputTerminal As
(3,453 Views)
ScotH,
This is likely due to the fact that the 6509 is port-configurable, rather than line-configurable. For your channel string, try "Dev1/Port11/Line0:7." If this does not help, let us know what you mean by "that did not work." Did DAQmx return an error? Was the terminal not in a high impedance state?
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,434 Views)
