Digital I/O
Trouble with PCI-6503, W2k and DELL computer
When I start my DELL computer sometimes W2k detect a new hardware. In fact the PCI-6503 config has disappeared. Without re-install the board if I reboot many times the computer, the PCI-6503 is known again and my Labview application works again. Is there a conflict with DELL computer and PCI-6503 NI ?
(3,619 Views)
Which is your service pack ? Which version of NI-DAQ ? Which is your computer reference ?
Isabelle J.
NIF
Isabelle
Ingénieur d'applications
National Instruments France
(3,619 Views)
service pack : W2K 5.00.21.95 pack 4
NI-DAQ : version 7.1.0f1
Computeur : Dell Optiplex GX270; Pentium 4; 2.8GHz; 256Ko RAM.
Regard,
(3,619 Views)
You can save your configuration.
To do this, in MAX and if you work with Traditionnal NI-DAQ :
1/ configure your device
2/ Tools >> TRaditionnal NI-DAQ configuration >> Save configuration as ...
3/ save the file (niconfig.daq) in directory C:\Windows
If you work with NI-DAAQmx :
1/ Configure your device
2/ File >> Export...
3/ Choose "system" and save the file *.nce.
4/ Then you can import your configuration file by File >> Import...
Isabelle J.
AE - NIF
Isabelle
(3,619 Views)
