Digital I/O
Troubles during an acquisition at 1.25MHz with PXI6534
Hello!
I encountered a trouble doing data acquisition at 1.25MHz using PXI6534: I work with LabWindows, I have a thread for the acquisition that only consists in a while(1) loop in which I call the Dig_Block_In and Dig_Block_Check functions and increments a counter to check the good state of the acquisition. I receive packets of almost 200Ko each 250ms so I call Dig_Block_In each time. Sometimes everything goes well, I can do long acquisitions but sometimes the acquisition doesn't start or stops after a few seconds. In my NI controller nothing works apart this application.
I have another PXI6534 card that does a very low acquisition using the same functions in a while(1) loop and everything goes well, I never had any problem.
I suppose that the high transfer rate is the problem. Also I saw in a forum that it's not good to do Dig_Block_In in a loop... Have you got other solution to do cyclic acquistions? Could you explain me what is continuous input because I didn't understand? Should I use continuous input? Have you got an example?
Thanks for your help.
(3,077 Views)
Hi Candie,
You can find in this link below information to acquire in continuous mode with NI-653x board, for make higp speed loop.
http://forums.ni.com/ni/board/message?board.id=70&message.id=1283&requireLogin=False
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=F0F644DE4AEC00FDE0340003BA7CCD71&p_...
Let me know if you need more information.
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,053 Views)
