Digital I/O
Troubleshoot PXI-6528
To whom it may concern, I accidentally damaged one or more of the I/O on the PXI-6528 when I connected the cable incorrectly. I do not have the time to troubleshoot all the I/O. Is it possible to send it back to you so that you can troubleshoot it? Thank You,Russ Szewczyk
(3,384 Views)
Hi Russ83,
To send your PXI-6528 in for repair, you will need to call in for support.  Read this KnowledgeBase for more information regarding this procedure.
Sara Lewandroski
Applications Engineer | National Instruments
(3,366 Views)
