Digital I/O
Tx digital data USB-6008
I'm transmitting digital bits with USB-6008 digital ports. I use all port 0, P0.0 to P0.7 and I'm interested in the output bit rate. I didn't find it in the datasheet, I only found the sample rate, but I don't know if there is a relantionship with digital output data speed. I want to know how to determine this bps. I hope your answers. Thank you.
(4,396 Views)
There is no sample rate/output rate in the datasheet for the digital I/O. As the specs and manual explain, digital I/O is strictly software timed so how fast you can write is dependent on your pc, os, programming language, etc. It is subject to a high degree of jitter. The stated max rate of an analog output is 150S/s so I would not be surprised if the digital output is about the same.  If you require anything other than static digital lines, you have the wrong device.
(4,395 Views)
Thank you. The device is that I just need, I only needed the bit rate for to do a report.
(4,392 Views)
Hi, iprados,
6008 digital lines are software timed. The update rate can only be as fast as your operating system timing source. If you are using Windows, the maximum software resolution is 1 millisecond, which means a 1 KHz frequency. On the other hand, this board has its own counter which is a a digital timed TTL line with its own hardware clock. In the future, if you need a device with a higher performance, I recommend you to purchase a new one.
Salu2.
Jesús.
(4,354 Views)
