Digital I/O
USB-6000 + NIDAQmx+ detect switch
I would like to recognize via a DI and a DO channel, if a contact is switched or not.
For this I want to set the DO channel high (+ 5V) and wire this to the DI channel via a switch. Then I read out the status on the DI.
I use a DAQ USB-6000 for this and the nicaiu.dll. I allready managed to read out a logical value on the DI channel. But I can't get a high signal at the DO port.
Many thanks in advance.
(1,411 Views)
It would be helpful if you could post the code for us to review and guide you better.
Santhosh
Soliton Technologies
(1,342 Views)
