Digital I/O
USB-6001 I/O voltage
Hi everybody,
The reference manual of the USB-6001 says in page 9 that the I/O voltage is 5Vdc.
I am thinking on using it to test a PCB where the microcontroller is powered to 3.3Vdc so the question is, ¿is it possible to connect the I/O power input to 3v3 instead os 5Vdc?
Thanks and best regards
(5,875 Views)
The specifications says (page 3) that the input high minimum voltage is 2.0V. So it should be no problem connecting it to 3.3V device.
Kees
(5,869 Views)
Hi again,
I forgot to put a couple of things.
What the hell is the pin +5V of the right connector for?
In page 23 it seems that the 5V come from the USB but in page 7 it looks like it isn't and that this pin is for power the module.
Any help will be apreciated.
(5,868 Views)
Hi K C
Thanks for your quick  response but i can't find this information in anywhere, ¿which document are you looking at?
I have   http://www.ni.com/pdf/manuals/374369a.pdf               and also the reference manual.
Best regards
(5,865 Views)
At page 4 of the link you posted. Although there it says Vih = 2.3V but still OK for you.
I cannot find the document anymore I found a few hours ago.
Kees
(5,855 Views)
Hi K C,
This Vih = 2.3V is the minimun voltage level to determinate a logic 1 and the Vil = 0.8V is the maximun voltage level to determinate a logic 0.
The input voltage range applied to input pins must be  between 0V and 5V.
My doubt is about the power supply in 15th pin. This is:
- What is the range of the supply voltage? it must be 5V or can be 3v3 as well?
(5,849 Views)
Accepted by topic author Alubeiro
The 5V pin is an output. The 6001 is powered by the USB interface.
(5,844 Views)
