Digital I/O
USB-6001 - suitable solid state relays
I would like to use a USB 6001 outputs to switch 24V but am not sure what the best solution is in terms of the hardware required - presumably solid state or optocoupler relays as this is for very low power equipment.
I believe the default configuration of the outputs is Active Drive which is 3.3 V with a current limit of 4 mA. I am struggling to find solid state or optocoupler relays within this spec (ideally DIN rail mountable - not PCB components). Is there a different configuration for the outputs on the 6001 that will give more flexibility?
(1,361 Views)
Found this in my 5 mins google search
https://www.winford.com/products/opi104.php
No, there is no other variant of 6001 with better capability since it is one of the cheapest DAQ. Of course, there are other models at a higher price range with better options.
Santhosh
Soliton Technologies
(1,352 Views)
