Digital I/O
USB-6008 Digital Amperage
I bought a 6009 for a similar application (solenoid valves). I am planning on using a smart MOSFET from Philips PIP3104-P. It's easy to use. Hope it can help you.
On the other hand, I am using Delphi and I am stuck when it comes to create a DO channel, so if any body has any idea (see thread Delphi USB 6009), they are welcome!
Cedric
Message 11 of 14
(1,405 Views)
Cedric78
That looks like a software issue unless your unable to write to the Digital Port using MAX.  gromar started a thread brought out other people working with Delphi.  I did not consider the Philips because I my pneumatic solenoids only require 5 volts.
Raymond
Message 12 of 14
(1,391 Views)
HI Raymond,
Thanks for the link, it 's got some useful information. I have sorted the problem by going for a coffee: just needed a break from the PC to realise the fool I was: not allocating memory to a pointer is looking for troubles!
I agree the Philips is an overkill, but it's easy to use Smiley Very Happy I use it to control small solenoid pumps (slow pumps) too...
Cedric
Message 13 of 14
(1,385 Views)
Hi Raymond thank you for your help I`ll review the link. If I need something I`ll write to you because i`m new using labview and the USB 6008.
Have a nice day.
C you.
Message 14 of 14
(1,370 Views)
