Digital I/O
USB 6501 Deployment
Now that my development based on the USB 6501 is completed, I am searching how to deploy the runtime application on different machines each equipped with a OEM 6501 and some of my hardware. The deployment of the USB 6501 is giving me headaches. I've included the 2 required assemblies into the GAC, (NationalInstruments.common and NationalInstruments.daqmx) and included the required dll into the system path (NationalInstruments.common.dll and .xml  and NationalInstruments.DAQMX.dll and .xml)
I am still missing some runtime dll as well as the USB 6501 driver.
I don't want to install the 400mb from the CD into the runtime machines, and I don't see into the documentation the information I need.
Question1: Where is the USB 6501 driver is to be found? (On the CD... but where ?)
Question2: What runtime Dll do I have to include (Of course this wil depends of the functions used, but where are they anyway ?)
Thank's for your support.
Thierry
(4,260 Views)
This question comes up all of the time. The only option NI has is to fully install DAQmx.
(4,256 Views)
I need to deploy just the USB-6501 usb drivers and support dlls to a dozen systems (WinXp) for an application written in VS 2008 vb.net using daqMx
How can I deploy the software without having to install the entire DAQMX v.9.3 package (over 1GB of files, most not required for the end system)
(it's been 5 years, surely this has been resolved by now)
thanks,
Thomas
(3,572 Views)
What you need is the NI-DAQmx Core runtime.  This contains the bare minimum needed to run a compiled program.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,568 Views)
Thanks Seth!
That's exactly what I was looking for, good to get these old threads updated, this was one of the first to pop up in Google...
Thomas
(3,545 Views)
