Digital I/O
USB-6525 SSR Output Current Limit
I plan to use the SSR outputs of the USB-6525 DIO device to control an inductive load as shown:
The manual lists a current limit of 500mA on the SSR output pins:
Is there internal protection against this limit, or should I use an external fuse in line with the input pin?
Thanks!
(622 Views)
Thanks!
I would put in a fuse, it doesn't hurt to be double protected than be relying on only one safety mechanism.
Santhosh
Soliton Technologies
(621 Views)
Appreciate the quick response!
(615 Views)
