Digital I/O
USB-8451 SPI transmission distance.
What is the maximum distance that the SPI bus can transmit and receive data from a slave sensor? It must depend on a few things like the clock frequency and types of buffer. What buffer do you recommend at the slave end?
(4,005 Views)
(3,986 Views)
Okay, but I can find no discussion of how long a cable can be run between the ADC in a sensor and the USB-8451.
For example:
http://www.ti.com/lit/an/slyt441/slyt441.pdf
(3,984 Views)
Accepted by topic author petercs
Although I can find no definite length, as you said, it will depend on multiple things, it seems that if people are using an un-shielded cable, then they start having problems around 3ft long, and shielded you can have the cable a bit longer. However this is very dependent on environment, which is why we can make no guarantees
(3,981 Views)
Okay Sarah, so probably safe at 0.5m. Which may be okay for some initial testing and develop a longer distance solution based on line drivers, clock feedback etc as in the TI document. The NI part could then be an FPGA card as we have many sensors.
Peter
(3,978 Views)
Based upon the TI information: SPI running at 100KHz should have around 100 ohms series termination along with a 1nF capacitance to ground.  This would imply that the desired frequency should be about:
Transmission Rate: ~ { 100 * [ 1 / (R * C) ] }
For the longest possible cable; keep to a transmission medium that has a controlled impedance matched to the R value to help control any line reflections.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,952 Views)
