Digital I/O
USB-8451 chip select lines while talking I2C
I intend to use the USB-8451 to communicate with a large number of I2C devices.
A power switching and monitoring device will contain a CAT9555 (An I2C DIO chip) and 3 x I2C current monitors.
there will be 64 of these power switching thingys.
I need some way of routing the I2C bus to the correct power switching thingy.
The DIO lines will be in use for over-current alarm inputs.
Could I use the API to put an address word on the SPI Chip Select lines even though I am not doing SPI communication?
I suspect that I could only drive one CS line at a time ?
Or would it be easier to just use a separate USB DIO ?
(5,612 Views)
Accepted by topic author krugman3
Hi Krugman3,
If you're using the I2C I'm not sure you'll be able to use the SPI API at the same time as it might cause a device conflict, it might be easier to use seperate DIO.
(5,476 Views)
