Digital I/O
USB-8452 as fast SPI slave
Hi! I have the USB-8452 and i need to use it as fast SPI module (12MHz). It is possible? If yes, where I can find some information? If no, have you plan to develop this feature?
(6,368 Views)
Hi Mario,
if i understand you problem, you want use 8452 as spi slave and try to performe as fast as possible data comunication. To respond to this call I am attaching this link:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-8452-used-as-slave/m-p/2236050
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-USB-8452-Master-Mode/m-p/2344318
I hope this information will be usefull.
Mario
(6,350 Views)
Can you provide more information about what you want in an SPI Slave? What functionality are you attempting to use? Are you testing a master? Emulating a device? Bidirectional communication or more of a half-duplex using the full duplex SPI bus?
(6,295 Views)
