Digital I/O
USB-8452 skew between CS lines
I am using an NI USB-8452 to control a device using a 5 wire SPI using the SPI scripting capability.
I want to be able to generate a trigger signal on one of the other chip select lines (CS) that occurs at the same time as the rising edge of my CS signal. However, there seems to be a huge amount of skew between CS0 and CS7.  For example, part of the SPI script executes:
fRet += self._lspi.ni845xSpiScriptCSHigh(self._cHdlScr, c.c_uint32(iCSB))
fRet += self._lspi.ni845xSpiScriptCSHigh(self._cHdlScr, c.c_uint32(iTRG))
where iCSB=0 and iTRG=7 (i.e. I want CS0 and CS7 to go high at the same time).
Is there a means to do this with the NI-8452?
(3,603 Views)
Hi AndyTPE,
Have you seen this forum post? It appears that this kind of delay is expected for the USB-8452, but there might be some tips and tricks that JBender1 used that you could implement as well.
Rita Prather
Software Product Manager
rita.prather@ni.com
(3,583 Views)
