Digital I/O
USB memory emulation (flash drive\HDD) for USB devices
Enybody have ideas how to emulate external USB devices through USB port in LabView (DAQ 6221)?
LabView be able to work with USB device, but I need to emulate this device for the others devices...
(4,490 Views)
Open MAX (Measurement & Automation Explorer), expand Devices and Interfaces, and on NI-DAQmx Devices, right click and select Create New DAQmx Device>Simulated DAQmx Device and select the 6221.
(4,486 Views)
Accepted by topic author <Alex>
Hello Alex,
There is a good KnowledgeBase Article about simulated devices that you should check out:
KnowledgeBase 3JLD2HB9: What are NI-DAQmx Simulated Devices and How Do I Use Them?
Dan King
(4,470 Views)
