Digital I/O
USB6501 MAX Timed Out While Waiting for a Driver
Hi
I want to use labview to control my USB6501 and make automatic long-time measurement. However, once a while, labview would fail to recognize the USB6501 and report error code-200220. The block diagram I use to control it is illustrated as the picture below.
I have observed that, when this happen
(1) NI device monitor display "No NI Devices Detected" while USB6501 is properly connected to my PC.
(2) When I click "Devices and Interfaces" section of NI MAX, a warning shows up and says "MAX timed out while waiting on a driver".
(3) If I plug another USB6501 now, the new device is not recognized as well.
(4) This problem can be solved by reboot my PC but it will eventually appear again after several hours or days without reboot.
I need the device to work stably and continuously for days without reboot so I am looking for any solution to solve this issue.
Some mehtods I have tried but fail include
(1) Double confirm all my USB6501 are functioning properly on a PC that just reboot. Also confirm the USB port of my PC is working properly.
(2) Follow this threads https://forums.ni.com/t5/LabVIEW/USB-6501-not-recognized-by-MAX/td-p/4282347 and reset MAX configuration data but it can still occur.
(3) Follow NI's trouble shooting page https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KeISAU&l step by step but none would work. I have also confirmed that my driver version and operating system are compatible.
(4) Reduce frequency of command to once per 10 second but it still occurs. Actaully this issue can also appear after I leave my PC on idle for days, so it doesn't seem to be strongly related to command line or labview control.
(5) Disable Windows 10 USB power saving mode but doesn't solve this issue.
(6) Repair DAQmx and VISA driver.
Below is a list of my driver version
PC  -  Windows 10 22H2
NI MAX  -  version 21.5
DAQmx  -  version 21.8
VISA  -  version 21.0
Labview  -  version 21.0
Thank you for your time. I would appreciate any comment and suggested solution.
Rootbeer
(1,452 Views)
For the USB Power Saving, are you referring to the USB selective suspend settings?
USB Device Disconnects and Reconnects Periodically on Windows PC
https://tmesystems.net/
(1,423 Views)
Hi ZYOng,
Yes, I mean USB selective suspend settings. I have disabled this function to keep USB always connected but unfortunately MAX can still lose USB6501 sometimes.
Thanks.
(1,418 Views)
Did you find a solution to your problem?
I also have regular ”timeouts while waiting for a driver” with some Rigol USB DMM and power supplies. Resetting the configuration file works sometimes, but the error eventually pops up again very soon.
I still can access the devices via PyVisa and still can see that they are working in the device manager.
(1,020 Views)
Hi nifrahi,
Yes, I solve the problem by disabling the NI LXI Discovery Service permanently.
1. press windows + R
2. enter "services.msc" and ok
3. find NI LXI Discovery Service and disable it
4. Restart PC
It never occurs again.
(1,011 Views)
