Digital I/O
Uisng the PCI 6503 to read a Digital port
  I am new to LabView. For one of my applications I am using PCI 6503 to read a 16 bit digital port from an FPGA board. I am having a single bit valid signal that goes high for certain time to indicate a valid data from the board. As PCI 6503 does not support change detection how can I get my requirement done with a PCI 6503 device.
Thank You,
Prasanth.
(3,577 Views)
Could you be a little more specific about 'goes high for certain time'? Since the 6503 is software timed, all you can do is have a DAQmx Read in a loop and if the bit is high, do another read of the port. You won't be able to poll any faster than about 1kHz.
(3,560 Views)
Dennis,
  Than you for the reply. Since I am using a PC the maximum rate at which I can operate is 1Khz. I have my output rate well within this limit. A polling rate of 1Khz is ok. I just want to confirm if polling this particular line is the only possible solution with a PCI6503 card.
(3,554 Views)
